Over the years my little to35 has stuck in gear a
few times.
The shifting rails are worn and need to be replaced,
however, you can stop this problem by insuring you
never pull up on the shifter lever when shifting.
Many times it happens when backing up, you stop and
shift to a forward gear, you have the shifter lever
in your hand and you pull up on it as you shift
gears.
You must stop this practice. At least it worked for
me.
few times.
gears.
me.
