Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: MF 285 engine rebuild
Masseynut(Australia)
12-01-2013 18:57:24
Early 318 Perkins engines have a rope rear seal, at least the 1080's here in Australia did have anyway. I'm not familiar with the 285's, as none ever came into this country as far as I know. Later engines may have come thru with a single lip type seal. Did you also get a lip seal in your kit? If you did, I'd just bin the rope set.
DavidP, South Wales
12-02-2013 14:05:37
 Re: MF 285 engine rebuild in reply to Masseynut(Australia), 12-01-2013 18:57:24
Hi,
My info agrees with Evan in that all 1080 and 1085 models had a rope seal. USA-made 285's with the A4.318 and A4.318.2 engines had a black nitrile lip seal. Part number is 2418F475.
DavidP, South Wales
Roy in UK
12-05-2013 01:02:54
 Re: MF 285 engine rebuild in reply to DavidP, South Wales, 12-02-2013 14:05:37
David, Is there much difference between the 318 and 318.2? I presume the latter is an improved version of the former. Did they manage to cure the notorious head gasket blowing proclivities of that engine? I seem to remember Massey sort of "gave up" on that engine when they replaced the 698 with the 698T. I have just been reading an excellent and very entertaining book by David Walker called "Inside Massey Ferguson" . He mentions the problems of the A4.318 fitted to the 1080/ 595 quite a lot. One of the funniest parts of the book though is when he talks about a tractor driver in Africa, who destroyed the engine in his 135 by replacing the dirty oil in the air cleaner with fresh new clean dry sand!
ecar
12-02-2013 17:19:26
Thanks guys.
Yep, the rebuild kit came with a lip seal also and I have that already installed. I didn't know if this rope seal was used for something other than the crankshaft.
Dieseltech, unless you are describing something different, I will toss the rope seal.
