I have a 135 4 cyl gas that my Dad bought new in Dec. 1965. Dad sold it in 1979 when he retired. I got it back bout 6 years ago. It was sitting in the previous owners barn not running. I winched it on the trailer and hauled it home. It had foil and clothes pins lining the gas line. The owners son told me it vapor locked, so they had to protect the gas line. It was so difficult to keep running they quit using it. Well I could fix it, I thought. It wasn't vapor locking because after I got it running It might run all day without a hiccup or it might not run 5 minutes. There was no pattern to it. I have worked on tractors for a lot of years, but this thing has me flustered. I rebuilt the carb twice, put in new plugs, plug wires, points, condensor, rotor button, dist. cap,
anything else I could think of. I even bought another tractor and switched parts. I tried another carb, and my carb worked good on the other tractor, my tractor wouldn't run with the other carb. I switched everything I could think of. The other tractor ran fine with anything I put on it from my tractor. Nothing from the other tractor helped mine. Carb, fuel line, sediment bowl, distributer, anything. I think it has to be fuel related, because when it starts missing, pulling the choke, will help it run for a while. It will idle, but give it any throttle, it will quit. Any time the governor kicks in it will quit. I even tried a new ignition switch. I tried adjusting the governor. Any Ideas?
