444 power steering
starting on the 444 I just bought a couple of months ago. Has a leak seems to be on the bottom side of unit ( unit is all under rad) Thought that by taking off rad the unit should come out, but from what I can see It looks like to get to the bolts you have to remove the front axle assemble. Has anyone had experience removing or working these? Any ideas what is leaking? Any help or suggestions would be appreciated thanks
I had a 444 with power steering and a narrow front end a few years ago was making a puller out of it and tried to remove that same assembly ( for weight purposes) had all bolts out and still couldn"t get it out. Good luck to you. Regards John
