TractorLinks.com
Show Parts for Model:
Re: power steering cylinder o rings MF 65
Patiolant
11-17-2013 11:47:58
When I did mine a few years ago, the dealer kit was universal for both types of cylinders (mine had the bolts) so there were parts left over.
Andrew in Georgia
11-17-2013 12:08:36
 Re: power steering cylinder o rings MF 65 in reply to Patiolant, 11-17-2013 11:47:58
Thanks, would you happen to know the stock number of the kit? I've been searching for hours and think I have the cylinder part number as 183074M91. Strange as it sounds this info is NOT in the shop manual that I have. It has pictures and descriptions but no part numbers. I've surfed the kit pictures and don't see the oddball seals I need. I am happy to see the piston rod is available for 30 bucks. Mine has a rough patch that I took out with some 400G sandpaper going around the shaft, not along the length of it. If that doesn't work then I can get a new one.
patiolant
11-17-2013 17:09:54
 Re: power steering cylinder o rings MF 65 in reply to Andrew in Georgia, 11-17-2013 12:08:36
830860M92. I did both the main and the power assist cylinder, and all seals I needed were in the kit. As said above, my main cylinder was the one with four large bolts holding it together. Good luck with it.
Andrew in Georgia
11-17-2013 17:35:36
 Re: power steering cylinder o rings MF 65 in reply to patiolant, 11-17-2013 17:09:54
I do thank you. After the entire afternoon searching I found the same number but it is great to hear a confirmation that it is correct. I found these kits from Turkey priced at 5.50 each, but you have to buy 1000 kits at a time. Looks like I'm spending about 70 bucks for the kit.
