Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 65 lift cover revisited
MF135 diesel
11-13-2013 07:54:16
I posted a picture on 10/14/13, page 7 under "Thank you David P". Definitely make the tool. I tried a punch and it is very hard to do since there is so little room to maneuver. I made the tool out of 1/4" steel with grade 8 bolts as the pins following David P"s dimensions. It worked great after heating the housing that the nut sets in. The fine threaded bolt inside I soaked with 50/50 acetone/ATF and then heated the sleeve in fits in very hot and it finally came loose. Just be patient and not try to force anything and it will eventually come loose.
