TractorLinks.com
Show Parts for Model:
Re: 65 lift cover revisited
samn40
11-13-2013 00:46:37
Brendan, first you need to loosen the small grub screw on the right-hand side. This tightens against a small lead ball to lock the threads.Sometimes you can get away with a blunt punch to loosen the nut sometimes you need heat.....sometimes you need a new nut! The inner bit is real difficult to tighten., in fact the easiest way is to cut through the rod with a hack saw so you can get something to grip to get it loosened, remember there is a roll pin through the end of this rod also. You can either weld the rod again or buy a new rod, they are not expensive. Sam
DavidP, South Wales
11-13-2013 01:44:52
 Re: 65 lift cover revisited in reply to samn40, 11-13-2013 00:46:37
Hi, further to Samn40's reply the attached photo shows the dimensions of what is for us the MF 163 Control Spring Nut Wrench. Time spent making one will be well rewarded especially if it is likely to be used on more than one tractor.
You can do as Sam suggestes or my normal way is to tack weld the rod head to the cup and use a stilson to unscrew the rod. You will need a lathe to remove the weld after. The thread is very fine so it is vital that you use a penetrating fluid such as WD40 immediately you have movement. There is a very real possibility that the parts will 'pick-up' and you will need to replacve both. When reassembling the rod MUST be adjusted so that the spring is tight to turn BY HAND. Don't forget to fit the rubber boot!
Follow remaining instructions as per the workshop manual.
DavidP, South Wales
