rosedale123
Did a compression check on the MH 30. all cylinders were 105 - so I don't think rings is why it smokes. It starts real easy and runs great - just smokes. The plugs are black and wet - uses some oil.
Could it be valve guides?? If that is it , can valve guides be replace without removing the motor? Does is take special tools?
Do you think this is probably the "culprit" ?
thanks for any and all information.
