bullheaded9668
New User
Ive been having problems with my 1105. Twice Ive ran it low on fuel and had this problem but this time its not working. The tractor would lose power but stay running then it would boost back up where it should be. Then sometimes it would die, the only way to get it started again was with either. We changed the fuel filters and pick up pump. Once we got it running again it ran fine until yesterday. I ran it low on fuel and it started giving me problems I filled it back up with fuel tried bleeding the system and no change, except instead of staying running it would die. I would start it again with either run it for a few minutes and it would sound great then I would take off and it would lose power then die. Today I changed the filters, bleed the system again and now it will start with either run for a min. and die. Im dont know if its the injection pump dirty and will need rebuilt or the injectors. When I crack the lines at injectors the tractor loses a small amount of power and fuel its spraying out, I tighten it and it powers back up. So everything fuel wise seems ok but I dont know. I just need this thing to run long enough to get me to spring time then its going to auction. Its been nothing but trouble. Ive replaced all the hydraulic pumps to get good pressure to my attachments and so I have some steering which still sucks and the steering pump whines like crazy but its a new pump and all pressures should be set right. Any help would be great.
