Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: MF-35 Thrust Washer
10-12-2013 04:24:03
Never seen thrust washers on a 35, thought all were part of the center bearing.
Ben Joseph
10-12-2013 04:44:22
 Re: MF-35 Thrust Washer in reply to 2tractors, 10-12-2013 04:24:03
I have the perkins diesel. Not sure how long it has been operated without the thrust washers, but it was running fine until I decided to change the oil. The drain plug was frozen and I couldn't remove it, so I decided to drain via the sump screen. When I removed it, I found the thrust washers lying across it.
10-17-2013 03:51:39
 Re: MF-35 Thrust Washer in reply to Ben Joseph, 10-12-2013 04:44:22
I ve seen a few of those recently with the same problem..good news is that a new crankshaft isn t very expensive, around $400.00. what s happened is that from constant use of the clutch, the shoulder of the crank has worn out. there isn t much else you can do to fix it, if you keep running it you ll eventually ruin the block.
