massey-harris-fergusen hydrolics
cloudhater
New User
Need help. 1956 t-35. Back hydrolics won"t work.
Replaced the relief valve, didn"t help. The oil is old and dirty some sludge on the bottom. Is there a pick-up that could be clogged?
I removed the plug at the top of the oil riser tube, right before the piston,NO pressure at all.
Any suggestions?
Ah the stand pipe yes oil should be coming out of the allen head screw if not the o rings are shot take the 2 bolts out that hold the stand pipe in pull it out & inspect
