AD4 203 rear oil seal
Brendon Warren
I'm trying to locate a new rear seal for my 65 Massey. This site shows the whole retainer with a new seal but not just the seal.By the way, it's the two piece rope type. I was also wondering how to remove the ring gear from the flywheel. Mine is pretty wore. If it comes off in one piece can you flip it over and wear out the backside. Thanks in advance.
Brendon
Rope seals are available from Agco parts for both the gas and diesel engines. Cost about $10.00.
Wayne
Warm up that ring gear and it should fall off! It can be reversed but they are not expensive. Remamber to soak that nes rope seal in clean engine oil for at least 24 hours before fitting, and do not be tempted to trim the ends!
Sam
Thanks Sam,I took the ringear off and flipped it this morning. It took about ten minutes. A new one was 43.00 + shipping. A penny saved is a penny earned. I just bought this one and ordered a water pump and hoses and a PTO clutch for it. I'm hoping the clutch solves my Multi power issues. It was saturated with oil. It's going to need new shoes soon so I need to pinch all the pennies I can.
