MF 135 checking plug wires
waynehens
New User
I need to make sure that the plug wires are on correct off the distributer cap. The plugs from fan to steering wheel are 1,2,3,4. The firing order is 1.3.4.2. When #1 piston comes up the rot should be looking at the dist. cap post for that plug and wire and the points should be open and so on for #3 etc. I need to know if this is the correct way to check. WH
when no. 1 comes up points will open thus making spark pushing piston back down pulling no. 3 up ect. you got it.
