Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Got the injection pump rebuilt...now I have fuel line leaks
Dieseltech
09-24-2013 15:06:26
Have seen the banjo fittings that have a mark left from the line ferrel. If line nut is tightened, loostened, and retightened 4 or 5 times you may get it to seal. May help to remove the banjo and flip it over too. The ferrel may or may not seal better that way. Line and banjo both may need replaced together if you can't get it to seal, one or both may have a small crack.
Jason S.
09-24-2013 17:36:47
 Re: Got the injection pump rebuilt...now I have fuel line leaks in reply to Dieseltech, 09-24-2013 15:06:26
Well I don"t guess it matters now. The pump is leaking exactly at the same place where it was leaking before I took it apart. Where the rotor and head assembly goes into the pump housing. It was leaking there and I figured that oring was bad. I was really careful when I put it back together and lubed the new oring and slid it together, but it"s still dripping.
