Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: MF 35 oil bath air filter question
papa T
09-23-2013 18:08:59
Thanks for the good instructions. I'm in the cleaning process and it was surely needed. I've also removed the carb to just have a look. Pretty sure it needs a kit, but I've never done one. Any advice you want to pass along will be helpful I'm sure. I do have a pretty good leak on the motor side of the carb, such that I can't leave the gas on when not running. Brief description of what happens while running. Starts with choke and will idle with no load. But I have to turn the gas outflow knob below the little filter bowl almost all the way off to continue running or it starts shutting down and dies. I'm assuming it is flooding it with too much fuel. Under a load it is even more likely to shut down, so that lately it's not running good enough to use. Well, any advice would be appreciated. Thanks again for the help.
maxwell99
09-23-2013 18:21:47
 Re: MF 35 oil bath air filter question in reply to papa T, 09-23-2013 18:08:59
I use non ethanol gas in my tractor.
it does sound like you need a carb rebuild. I would not go cheap on the carb kit. Get one from Napa or dealership.
Must clean carb well before rebuilt.
May want to add a inline fuel filter between cutoff valve and carb.
Good luck,
papa T
10-11-2013 05:47:14
 Re: MF 35 oil bath air filter question in reply to maxwell99, 09-23-2013 18:21:47
Did the short term of cleaning and refitting oil bath filter and some cleaning of carb without going inside. I know I"ll need to put a kit on the carb soon but wasn"t ready to do that just yet. Put it all back together and it runs better. At least well enough to get my place cleared away for Winter. Thanks for the good help. I"ll probably be back on here when I tackle the carb. :) Thanks again.
Copyright © 1997-2015 Yesterday's Tractor Co.
