Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: MF Transmission Fluid Questions
Tom from Buckeye Lake
09-21-2013 12:48:01
The dip stick by your right foot is the ONLY one for the trans/differential. If it reads full on level ground ur good to go :-)
The inspection plate under the tractor is for access to PTO clutch adjustment. There is a bent cotter pin hanging from a hole in her belly, that is to keep the hole open for any seal leakage.
I drilled an extra hole in the center of the inspection cover, installed another cotter pin in it also. Then if you have an oil leak, front hole=engine, rear hole=transmission.
Roger Hoff
09-22-2013 07:43:59
 Re: MF Transmission Fluid Questions in reply to Tom from Buckeye Lake, 09-21-2013 12:48:01
Thanks for the info Tom.
