Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: MH 44 internal engine oil line
09-20-2013 08:41:14
Larry -
The oil pump mounts to the FRONT main. As others have said there is a bushing that fits in between the pump body and the front main cap. Without it, you will not have pressure. Please see the attached diagram for the fittings and pickup tube that you are needing...
Larry Horse
09-20-2013 12:34:52
 Re: MH 44 internal engine oil line in reply to Goldsburg, 09-20-2013 08:41:14
The pump is mounted on. I Am just curious what that 1//2 inch hole in the pump housing on THE OPPOSITE SIDE of the pump pick-up is for, it is not a threaded hole, I am concerned that with nothing in that other hole the oil pick-up will not perform.. I don't have a picture, but there is also a brass fitting coming out of the REAR main rod cap, Maybe someone tapped it to try to spray oil at the piston bottoms for pulling or other non-sense. THANK-YOU so much I know I am trying your patience with these dumb/abnormal questions. I will try for some pics.
09-20-2013 08:48:38
Correction: The bushing (ring dowel) to hold pressure is between the main cap and block. See attached diagram:
09-20-2013 08:42:11
