Anonymous-0
My 165 is not starting nor will it stay running after being jumped. When I bought the tractor the previous owner told me that it probably needed a new battery. It ran fine the first day I had it, but the next day it wouldn't start. I jumped the tractor, but it would only run for a few minutes. After replacing the battery the tractor ran fine for several weeks then recently it wouldn't start. It doesn't make any noise at all when I turn the key it would start and run when hooked up with jumper cables, but whenever the cables are taken off it would die. I had the generator tested and it apparently is fine. I also replaced the plug wires, but still nothing. Anyone have any ideas?
Thanks
Thanks
