TractorLinks.com
Show Parts for Model:
Re: 202 Lost Oil Pressure
DS43812
08-20-2013 06:52:38
Tear the gasket at the back of the engine? If you're referring to the mating surface between the engine and transmission, no gasket is used there, only a thin film of gasket shellac.
Even if a gasket were used, only the damaged portion of the gasket would need to be replaced, without the need for splitting the tractor. A similar area that comes to mind is the timing cover, where the front portion of the oil pan gasket is damaged when the timing cover is removed. In this case, replacing only the damaged portion of the oil pan gasket when reinstalling the timing cover works just fine.
