Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 202 Lost Oil Pressure
vt parts
08-20-2013 04:25:52
When you remove the oil pan most likely you will tear the gasket at the back of the engine. The only way to replace it is to split the tractor.
Since you really don't know what you will find when you take the engine apart, my advise would be to remove the loader frame before doing any work. It is going to be in the way and if you need to remove the engine for a major it is really going to be a problem.
DS43812
08-20-2013 06:52:38
 Re: 202 Lost Oil Pressure in reply to vt parts, 08-20-2013 04:25:52
Tear the gasket at the back of the engine? If you're referring to the mating surface between the engine and transmission, no gasket is used there, only a thin film of gasket shellac.
Even if a gasket were used, only the damaged portion of the gasket would need to be replaced, without the need for splitting the tractor. A similar area that comes to mind is the timing cover, where the front portion of the oil pan gasket is damaged when the timing cover is removed. In this case, replacing only the damaged portion of the oil pan gasket when reinstalling the timing cover works just fine.
Copyright © 1997-2015 Yesterday's Tractor Co.
