TractorLinks.com
Show Parts for Model:
Re: massey 135 oil leak
DavidP, South Wales
08-19-2013 13:28:59
There are several things that can cause strange noises. The springs on the release lever/s can break and be thrown out and make contact with the casing. If the release levers are being pushed in too far they can make contact with the pto plate and make pto engagement difficult or impossible.
Make a note of how much clutch pedal free travel you have and slacken the pinch bolt and increase it slightly. If the noise stops then it may have been the fingers contacting the pto plate.
Another possible cause of a rattle when the pedal is fully pressed is a worn pto flywheel plate. It locates on three heavy lugs on the main pressure plate. When wear occurs the ptoflywheel plate will 'fall' slightly as the flywheel turns. This causes the noise.
DavidP, South Wales
