TractorLinks.com
Show Parts for Model:
Re: massey 135 oil leak
rong
08-18-2013 22:15:29
Thanks,David for your response,I cant tell if it is engine oil or trans oil, obviously been slinging around in bell housing for quite some time, got my shop manual this afternoon,got sent out of town this week for work,should have plenty of time for reading in the evenings,one more thing I didn't mention earlier is when clutch pedal was all the way down,slight ticking/grinding coming from Bell housing area.
I looked inside and can see where something is grinding the housing on both sides,but cannot see any marks on pressure plate,or clutch housing.again thanks for your input.
DavidP, South Wales
08-19-2013 13:28:59
 Re: massey 135 oil leak in reply to rong, 08-18-2013 22:15:29
There are several things that can cause strange noises. The springs on the release lever/s can break and be thrown out and make contact with the casing. If the release levers are being pushed in too far they can make contact with the pto plate and make pto engagement difficult or impossible.
Make a note of how much clutch pedal free travel you have and slacken the pinch bolt and increase it slightly. If the noise stops then it may have been the fingers contacting the pto plate.
Another possible cause of a rattle when the pedal is fully pressed is a worn pto flywheel plate. It locates on three heavy lugs on the main pressure plate. When wear occurs the ptoflywheel plate will 'fall' slightly as the flywheel turns. This causes the noise.
DavidP, South Wales
