The oil pressure on my '59 Gas 202 Work Bull has been low, and last night the gauge didn't even budge and it started making a bit of a dry squealing noise. I pulled the oil filter canister off and started it, nothing coming out. It still runs, no knocks, so I'm hoping I can fix it.
I have never worked on this engine aside from tuneups. I assume the oil pump is inside the pan? Does the pan come off without major disassembly? Are there any other tests I can do while it still runs? Seems odd the pump would wear out completely, anything else it could be? It has never run low on oil.
Thanks.
Thanks.
