Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Stuck 3 Pnt Pin
Masseynut(Australia)
08-14-2013 03:58:19
You don"t need to remove the pin to re-kit the ram.
It may be awkward, but the rod can be removed from the cylinder by first removing the hydraulic nipple/fitting from the cylinder.
Pull the rod out of the cylinder, while looking thru the port in the cylinder and you will see a circlip on the end of the ram rod. With a screwdriver or equivalent, pry the circlip into the next groove beside it. It will be slightly deeper, and allow the circlip to clear the ram casing when the rod is pulled further outwards. Once the rod is out, you can replace the leaking seals, Evan.
bill from scotland
08-14-2013 11:17:53
 Re: Stuck 3 Pnt Pin in reply to Masseynut(Australia), 08-14-2013 03:58:19
Evan
Thanks for the advice, as you will see I actually managed to seperate the two parts which should make it easier to do.
Bill
Copyright © 1997-2015 Yesterday's Tractor Co.
