TractorLinks.com
Show Parts for Model:
Re: Massey Ferguson Governor Problem
DS43812
08-11-2013 10:34:01
After checking everything imaginable, I've come to the inescapable conclusion that the bumper spring must be what is causing my low speed governor problem. After carefully checking it per the instructions found at FENA, a small amount of bumper spring action was noted at the idle position which will require removing the timing cover to bend the bumber spring back slightly.
However, this has proven to be a blessing in disquise. As I was draining the radiator and preparing to remove the crankshaft pulley, I noticed that one of it's three webs or spokes is cracked. This explains a previously unidentified vibration I experienced at certain throttle speeds. Thankfully the crankshaft pulley came off somewhat easily, so I won't have to remove the entire front of the tractor to remove the timing cover.
