Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Massey Ferguson Governor Problem
Jason S.
08-10-2013 16:22:14
Go over to the Ferguson board and find John (uk). He is a retired Ferguson/ Massey Ferguson mechanic. Send him an email and he will send you the procedure for adjusting the governor. His method is a little simpler than the shop manual method. I used his method and mine works great. You might want to replace the governor compensating spring because they lose their tension after all these years. Make sure you don't have the bumper screw turned too far in because that will keep the governor from working. Just back it off and unless your governor surges leave it backed off.
DS43812
08-10-2013 18:02:12
 Re: Massey Ferguson Governor Problem in reply to Jason S., 08-10-2013 16:22:14
Thanks for the suggestion, I'll create a post in the Ferguson forum and see if he responds.
I forgot to mention that I had also backed out the bumber screw and ensured that it was not contacting the bumber spring so I'm fairly confident that it's not causing my problem.
Jason S.
08-10-2013 18:20:15
 Re: Massey Ferguson Governor Problem in reply to DS43812, 08-10-2013 18:02:12
He hasn't been posting on the board in a while but he still responds to emails. I have his directions saved and I had sent them to a few people needing them but somebody a while back said something on the board about people sending his directions to other people without his permission so I quit doing that. If you are on the tractor and you have it in high gear and hold the brake and let the clutch out does the governor arm move? If the bearing on the governor arm inside the timing cover goes bad it won't let the governor work like it supposed to. Did you orient the tab on the governor correctly before you put the timing cover back on?
DS43812
08-10-2013 18:48:12
 Re: Massey Ferguson Governor Problem in reply to Jason S., 08-10-2013 18:20:15
The bearing on the governor arm is new and was properly lubricated prior to assembly. The governor arm itself moves freely with no hint of binding.
When seated on the tractor I tried observing the governor arm movements as per the instructions but I honestly can't tel if it's moving or not. My eyes tell me it's not moving but my view is restricted by the manifold heat shield so I can't say for certain either way. Tomorrow I'm going to have my wife video the governor arm as I lock the brakes and shift it into high gear to bog the engine down very briefly a couple of times to see if it moves or not.
Regardless, the tractor slows down considerably when a sudden load like a plow or box blade is applied by engaging soil, or by going from a level surface onto a slope. My first thoughts were carb and/or timing but they have both ben carefully checked and found to be withing spec.
It's got me stumped.
Jason S.
08-10-2013 19:08:16
 Re: Massey Ferguson Governor Problem in reply to DS43812, 08-10-2013 18:48:12
Have her watch and let me know what you find. We will get it figured out.
