perkins 3a 152 rebuild
Davefeeny
New User
rebuilding an engine mf 35 crank shaft and wore out grove for strust washer , Grove partially there but washer will move. cant find block. was told by mechanic that he has in past in similar situations screwed trust washer to block using small screws counter sunk. any thoughts ??? very low usage 50 hours a year max.. if i could get another ten years, would be happy . any thoughts ???
Any good engineering shop should be able to fix that by machining and fitting over-sized thrust washers.
Sam
