Injection pump gasket. MF35 3 cyclinder diesel
Matt Rowley
New User
Hi My MF35 3 cylinder Perkins diesel had a leak in the injection pump where the throttle rod connects. I took off the cover of the injection pump and found that it was a simple two O ring replacement. I replaced the two O rings and put the cover back on. Then it weeped at the gasket. I obviously should have replaced the gasket especially since I broke a bolt trying to over tighten it to stop the weep. (I know, I know. What a goose!!!) Anyway I can't seem to find where I can get a new gasket from. Is there somewhere or is it just easier to cut one.
Any good fuel shop that des CAV work should havethem. Next thing when you take it off make very sure the surface is flat. I have had to lap a few of them because they leaked because they were not flat any more.
Thanks to you both for your reply. As I said I stupidly broke one of the bolts. They are a double ended bolt so I have unscrewed it from the injector. I don't suppose they are available to purchase.??????? They look like a pretty specialized bolt. Thanks again Matt
