leaky transmission mf175
kuntryboy
my 175 leaks hydraulic fluid somewhere in the front. it just went through the shop and replaced the seal. i teddered and raked about 6 acres. when i stopped in my driveway to grease my rake i saw oil on the gravel. i think it leaks when it"s running but can"t tell where. it has a multipower transmission. anyone have an idea what might be leaking? i"m sure it will have to be split again, but to fix what?
See if its leaking out the weep hole under the clutch. Don't plug the hole if that's where it leaks. That hole should have a cotter pin in it and is to let oil leak instead of soaking the clutch. Requires a tractor split to replace the seals.
