TractorLinks.com
Show Parts for Model:
Re: MF35 FEL hydraulic pump connector shaft
Luthier
07-30-2013 19:17:07
Sorry, the forum changed my links to the images.
The shaft that connects the drive shaft to the hydraulic pump is most likely twisted off. It doesn't turn when the engine is running and I put a shaft in it tonight with key to turn it out and it just spins... this is really bad.
Anyone take the front end off the engine with a mf mod#100 loader on it? I can only see the amount of damage I'll be doing to myself when I try to move lift arms that probably weigh 500lbs...
I can't wait until this forum allows me to post photo links so you can all see what I'm talking about..
matt p
07-31-2013 06:34:55
 Re: MF35 FEL hydraulic pump connector shaft in reply to Luthier, 07-30-2013 19:17:07
You can pull the front end forward if you jack up the loader about two feet,this will give you room to separate front from motor,giving you access to the front axel. I used a large rolling jack under the bucket of the loader to lift it then blocked it up,this let you move the front end against the loader crossmember and just enough room so you don"t have to remove loader goodluck
