I have been getting diesel fuel in my crankcase. Seems to accumulate while parked, shutoff. Dealer shop worked on it and
Its still not fixed. They said only 2 things can cause this, either the lift pump or injector pump. Both have been worked on. So I suspect fuel gravity feeding through a leaky injector. But I am not that familiadr with such possibilities on a diesel engine. Theolder engine doesn"t have a solenoid valve to cut off fuel when shut off, and the tank being higher than the engine maybe it can dripinto cylinder and bleed into crankcase. ???? It runs good when running. But I cant run it now. If so, who works onthese old injectors???? Someone good at it.???
