Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: installing a set or hydraulic remotes on a 35 massey del
07-29-2013 11:05:18
Under the right front corner of the seat there is a plate on the top of the transmission. You can replace that plate with a valve that will switch the hydraulics from the 3-point to your auxiliary "what-have-you"... First drawback, you can't use both the 3-point AND the auxiliary hydraulics at the same time.
07-31-2013 06:16:38
 Re: installing a set or hydraulic remotes on a 35 massey del in reply to Chip812, 07-29-2013 11:05:18
My Deutz 4506 has remotes setup that way, the tractor had a loader on it when I got it, Using those remotes, it was painfully slow, I removed the loader from the tractor as it was useless to me. I agree, lift pump hydraulics are SLOW if using something with high volume flow. Either a PTO pump or a front pump would be recommended.
