Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: To35 Lift
DavidP, South Wales
07-28-2013 15:45:27
Hi, to add to what Inno has said;
On the front area of the lift cover you will see 4 larger nuts in a rectangular pattern. Check carefully to see if any of them have moved. They will probably be 13/16"AF socket size. Try a socket or spanner on each one and see if they move. If any of them move that would suggest a broken lift cylinder.
DavidP, South Wales
Joes Massey
07-28-2013 16:09:01
 Re: To35 Lift in reply to DavidP, South Wales, 07-28-2013 15:45:27
Took seat off ,didnt see any cracks in housing.Checked the 4 -3/4 nuts in a rectangler pattern.One of them was loose,other 3 tight.Do I pull the whole top plate off now,or is there some thing else I need to check?I really do apprecitate the help.
DavidP, South Wales
07-28-2013 16:54:51
 Re: To35 Lift in reply to Joes Massey, 07-28-2013 16:09:01
Hi Joe;
One or two loose bolts indicate a broken cylinder. Nothing short of removing the hyd cover now. It would be advisable to buy a good workshop manual or at the very least take detailed photos of the way the linkage between the control levers and the pump lies once you have the cover off. It's very easy to put it back wrong. When you have stripped it as far as the cylinder and removed it examine the studs very closely. They are a precision fit in the cover. If any are bent you will not be able to start them in the new cylinder. Fit a new O ring between the cylinder and cover.
Let us know what you find and if you need any more help.
DavidP
Joes Massey
07-30-2013 15:18:33
 Re: To35 Lift in reply to DavidP, South Wales, 07-28-2013 16:54:51
Ordered a DVD today.We'll see how it goes.Thanks to all for the input.
Joes Massey
08-04-2013 08:28:47
 Re: To35 Lift in reply to Joes Massey, 07-30-2013 15:18:33
Got the top plate off today.It split the lift cylinder.So I am on the hunt for another one.Any suggestions?
