TractorLinks.com
Show Parts for Model:
Re: MH Pony Generator Not Charging
51Pony
07-26-2013 13:35:20
do you have the 3 position light switch in the right setting?
Palpatine
07-27-2013 19:34:00
 Re: MH Pony Generator Not Charging in reply to 51Pony, 07-26-2013 13:35:20
I think so. I've tried all 3 positions with the tractor running, but none of them seem to make a difference in the charging.
51Pony
07-28-2013 04:51:24
 Re: MH Pony Generator Not Charging in reply to Palpatine, 07-27-2013 19:34:00
do you have a wiring diagram to make sure everything is wired up right?
Palpatine
07-29-2013 19:35:26
 Re: MH Pony Generator Not Charging in reply to 51Pony, 07-28-2013 04:51:24
I do. I put a new wiring harness on it, which had instructions and number-coded wires. I'm pretty sure it's hooked up right. The wire coming out of the generator (through the rubber grommet) is connected to the screw on the underside of the cutout relay. The blue wire is on the generator's field post, and goes to the light switch. The red wire is on the cutout's BAT terminal and goes to the ammeter. The new light switch came with instructions, too, and I believe I followed them correctly.
Palpatine
08-20-2013 20:10:20
 Re: MH Pony Generator Not Charging in reply to Palpatine, 07-29-2013 19:35:26
Well, as it turns out the generator was the problem. I took it to a resident generator guru and he repaired it. Now it"s charging like it should. Thanks everyone for your responses.
