Tracy Ellis
New User
After removing the pressure control system and installing a relief valve on my Ferguson pump and adjusting the top cover on my 135, everything was working fine. I noticed that the Ipto started to turn, and the lever was in the off position. I shifted the lever to on and the gauge read zero, which had been reading around 350psi. I removed the top cover again, 3rd time, and found the relief valve was loose, when I tried to tighten it I found it cracked. Has anyone ever tried to replace the relief valve by sourcing an universal one and some hydraulic fittings. Thanks
