TractorLinks.com
Show Parts for Model:
Re: Massey 1105 Lift Arms suddenly INOP
ben brown
06-28-2013 19:37:54
well i have one that did that yesterday on right side under the lift arm is a small plate the valves stick sometime you can move them with a screw drive and get then to free up my problem was it raise but not lower was able to get it to work now proble is that pump only has 1250 on remotes so not enough to raise the cutter bar or cutter at all. my question is that it looks like one can remove relief valve for main pump from bottom i hoping that solves the problem cleaned the charge pump screen and change main hyd pump today but no better though it does raise and lower as it should but with only 1250 psi wont lift much i open for suggestion as i don't work on a lot Massey the agco parts on line parts book is a big help
