TractorLinks.com
Show Parts for Model:
Re: 2Q's for MF 202 - Lift Hydraulics & Rear Tires
Inno
06-25-2013 21:29:30
Only suggestion I have is look up the loader on agcopartsbooks.com and see if you can find someone closer. It is for the exact same reason that I have never tackled a hyd. cylinder rebuild, too many things that I don't know about them and what could potentially cause them to leak and or bypass. Need to learn soon though as my backhoe is in desperate need of some help.
RuralTowner
06-26-2013 17:33:14
 Re: 2Q's for MF 202 - Lift Hydraulics & Rear Tires in reply to Inno, 06-25-2013 21:29:30
Rebuild...insofar as the seal in the nut. Found 2 possible leads on parts. Both are closer than the Phoenix options...both are in the same town about an hour's drive away. Got to one too late to hear much so will check back tomorrow. If nothing turns up with either I guess I'll just have to see if they can MAKE the seal...I know some places do that. The rest of the cylinder is fine.
Sadly not knowing what model (for sure) the loader is doesn't help.
Is the 100 Loader a separate model from the Davis 101//102?
Grr...heat-rotted old rubber.
