Frank in Mo.
New User
Changed oil in transmission and hydraulic system due to excessive noises. Still have lots of noise and see extreme turbulence in oil while looking through the fill cap with engine running.I know the noise shouldn't be there but need to use tractor to cut hay.
Is the turbulence in the oil normal, and if not what could be causing it. Thanks for helping.
Also, next post I'll have to try explain the noise, maybe someone out there can hep me pinpoint the cause before i have to split the tractor or cause more damage.
