Frank in Mo.
New User
Trying to find out what oil to use in hydraulic and transmission of a 165 I purchased at auction.Right now it has a very thin oil like a universal hydraulic fluid. When running there is noise in the transmission and when shifting multipower from high to low it squeals. After the oil heats up there is excessive noise an the oil is thin.
The maintenance manual says to use M-1129 oil only available through the dealer. Called the dealer, says to use there perma lube which is a thin universal hydraulic fluid. Dealer did not find information on M-1129 oil
Please help, should this be a straight 90W oil like the MF50 use.
What is M-1129 Massey Ferguson oil?
