alright so i have a massey 165 and it seems as if it has a bit of a hydraulic issue. The tractor was just in the shop cause i completely lost hydraulic pressure, both at the remotes and at the lift arms. They though it might be the pump but then they decided it wasn't (super happy bout that) but they did some other work to it and said it was good to go. The remotes now work ok and the 3point hitch does too but the 3 point hitch especialy is really slow. I have the response lever the whole way up at fast and it still takes a good bit of time to raise up an implement. Even stranger it takes a good while for the implement to go down. Anther issue with it is that when you go to hook up to an implement the lift arms will not go down unless you get off the tractor and go back and jump on them. no matter what you do with either lever. they will not go down without wieght. So is this normal? i dont figure that it is but i would think that after spending 2500 at the MF place it should work like any other tractor.
any ideas for a fix would be greatly appreciated
