Pony Rear Wheels
Pony1952
Back wheels have not been off tractor in 20, plus years. Removed the lug nuts, but wheel does not come away. Is there something else necessary to remove, or is it corrosion and other garbage keeping wheel on at this point?
I allways thread the lug nuts back on finger tight before I smack any rear wheels with the sledge. When it pops off, it will be held on the hub and not coming after you. Could be bad if the tires have fluid.
