TractorLinks.com
Show Parts for Model:
Re: massey ferguson 175 extrenal hydraulics
steve10220
06-23-2013 10:24:25
I don't see anything on the tractor that says multipower ( don't know what that is ) the motor only loads down when the disc is hooked up ,the 3 point lift works fine.
I have new lines, new couplers and cylinder. I unhooked the cyl from the disc and the cyl still will not extend or retract more than 2-3 inches with no load. I don't have a gauge....
I hooked the disc up to a White 2-70 and it works perfectly - do not want to have to borrow neighbor's tractor to disc my place up tho....
When you engage the lever - the wheels on the disc jump about 2-3 inches like they want to go, but stop-this is in either direction up or down, the hyd lines jump when the pressure hits them, either one depending on direction and then the motor loads down - it's like it's trying to work but can't
The disc is a 10 ft long, and the guy I bought it from was also using a 175 ferguson. He has since moved away and I cannot reach him to get advice on how his did with it - but I had seen it work with his tractor before I got it.
I am hoping it's just a minor adjustment maybe from a single acting cyl to a double acting one - but I have run out of ideas and giving out of want to's.I did not want to have to get a mechanic out here if I did not have to - so any suggestions or possible routes will be greatly appreciated.
Thanks again - Steve
