TractorLinks.com
Show Parts for Model:
Re: MF 50 Hydraulic Cylinder Repair
Masseynut(Australia)
06-21-2013 00:13:38
Problem with this style of ram head, is that the weather gets down thru where the wire clip is fitted, then rusts the barrel to the head. The orifice should always be sealed after refitment with a small amount of silastic, simple. Now, you may need to take to the outer area of the cylinder in the area of the ram head, with a hammer.... I'm not kidding! Rest the cylinder on a heavy anvil or equivalent, and hit the opposite side of the barrel with the hammer. Repeat this process all the way around the diameter of the cylinder. What you are attempting to do, is to slightly "stretch" the cylinder metal. This will eventually give you a small amount of clearance between the two parts. Now, take to it with your spanner, taking care the that the wire ring also turns with the head. THIS IS IMPORTANT, cause if it doesn't, the tag on the wire clip will break off in the ram head, making removal of the clip almost impossible, believe me. Been there, done that!!! Let us know how you get on, regards, Evan.
R.L. Fusco
06-25-2013 15:26:34
 Re: MF 50 Hydraulic Cylinder Repair in reply to Masseynut(Australia), 06-21-2013 00:13:38
Hooray ! it worked. I did soak the parts in penetrating oil (Kroil, acetone,Automatic transmission fluid and wintergreen) for a day before giving it the "ball peen treatment" but it loosened after about two-three revolutions of the cylinder on the anvil.
Thank you very much for the tip.
Bob
R.L. Fusco
06-22-2013 05:54:52
Thank you Evan, I will do as you have suggested, actually My Dan a plumber used this method to loosen rusted iron pipes, I should have remembered it !!!
Thank you,
bob
