TractorLinks.com
Show Parts for Model:
Re: mf 135 independant pto
Tom from Buckeye Lake
06-17-2013 19:14:30
Your IPTO pump filter is clogged. On my 150, I could lever a 2x4 against the PTO shaft and stop it. There is a small plug near the lever where you can install a pressure gauge, should be 125-150 PSI. Mine was down to 35 PSI.
Now the really bad news, you will have to remove the top-link cover to get to the filter.
I'll post a picture for you in the morning, I'm on a tablet and the pics are on my computer.
06-18-2013 05:28:04
 Re: mf 135 independant pto in reply to Tom from Buckeye Lake, 06-17-2013 19:14:30
Pictures of 150 with IPTO
a49deere
06-19-2013 02:44:14
 Re: mf 135 independant pto in reply to Tom from Buckeye Lake, 06-18-2013 05:28:04
Tom: Wouldn"t the pto gradually stop working correctly if the filter was plugged rather a sudden problem? Just curious. thanks for the reply I will look into that. GREG
06-19-2013 05:45:26
 Re: mf 135 independant pto in reply to a49deere, 06-19-2013 02:44:14
Relief valve could of stuck open, pump gone south, clutch plates broken or warped. 1st is to check the pressure. Pressure at test plug only when lever is engaged. Any repair require you to open the lid.
