Hi. I am not a Massey guy just fixing one for a guy down the road. He brought it over and said it had a nocking noise. By chance I noticed the front pulley was loose. The flange area that the bolt rested on to hold the pulley on was broken. Letting the pulley move in and out and wear the key and key way. I figured that would fix it no problem. Well I admit it is better but still noisy. It sounds real nice under a load and at higher rpm. It is VERY noticeable at low RPM. I am wondering could it be the governor weights?? Perhaps a timing gear? The noise is in the front of the motor. To me it is more of a clatter than a nock. O yea also the owner and his brother rebuilt it and it has been run very little since then. I understand it didn"t run when he got it and it nocked when the put it back together. Any help is appreciated.
