Anonymous-0
If PTO is engaged and roto tiller lowered to the ground -when I release the clutch the pto stops turning and tractor moves ahead but seems like it is in a higher gear than 1st If I now shift the main transmission to neutral and release the clutch it still tries to drive the tractor forward and the pto is locked up If I disengage the pto it drives properly and recognizes neutral The pto turns fine until it engages the ground. Mty tractor has the dual or live two position clutch and is driven by 3 cyl Perkins diesel. Am I looking ata clutch issue or a PTO-any suggestions
