Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Perkins 3 cyl gas carburator
06-08-2013 16:15:12
I have the same engine in my forklift, carb apart once for cleaning, still works fine. May need to check the main jet, may be partially blocked. Carb should still work OK if float is set 1/16 inch lower as mine is. Had to use hotter plugs as forklift idles a lot, kept gas fouling standard heat range plugs.
06-09-2013 09:12:04
 Re: Perkins 3 cyl gas carburator in reply to Dieseltech, 06-08-2013 16:15:12
I have had this carb apart 6 or 7 times. The first time I cleaned and installed a carb kit. After setting the float as per the instructions with kit and reinstalling the carb when I turned on the gas it just ran out of the carb. I took it off again and reset the float and gas did not run out but after starting it would idle perfect but when trying to ref it up it would starve out and die. I have had the carb off several times since and rechecked all jets and reset the float but can't seem to find a happy mediam where it will ref up and not just pour gas out.
