Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Massey 255 bushhogging position issues
gbs
06-03-2013 17:52:02
that"s correct the draft lever needs to be in the full up position ,draft is for plows and other draft implements when it is used the position control has to be in the full up position, the position control will enable the lift to be set at any position as long as the draft lever is in the full up position,some lifts were available with a pressure control that used the position lever to control both,if yours has there pressure range on the lever guide just use it in the position part of the travel,2 things that will help with your bush-hog hitting the ground on uneven ground is to use a tail wheel and a floating top link hookup on the on the bush-hog these will allow it to follow the contours ground better
William Garner
06-03-2013 18:26:37
 Re: Massey 255 bushhogging position issues in reply to gbs, 06-03-2013 17:52:02
Ok thank you I will try that.
Copyright © 1997-2015 Yesterday's Tractor Co.
