Anonymous-0
I have a problem with a MH50 When the front end loader is locked out in a raised position and the rear three point linkage is raised, the 3 pt linkage begins to slowly go down. The oil is very clear and to the correct level. I took the tube out of the top of the box and fitted new o-rings as they were half missing anyway, but the lift still slips down. Could this be the relief valve worn out or something else. This farmer uses the draft lever fully raised, but I try to tell him not to, so, perhaps he has damage done somewhere. You can hear the pump rattling well in full draft raised position. I am pretty sure the lift is pumping well, but I have a leak somewhere to deal with.. Any ideas.
