1105 weak remote and 3pt
mhudgins
my 1105 has a weak 3pt hitch and slow or weak remotes
changed everything fluid filter and cleaned other filter under charge pump nothing change steering is easy can turn with one finger does anyone have any ideas where i could start
Steering priority valve. Its just ahead of the firewall up under the hood. The main line from the pump goes to it, then splits to the steering and aux hyds.
Pull the steering clear to the upstream right or left and hold will raising the three point. If it helps the three point you do have a priority valve problem.
